shockinyall
New User
Hello All,
First things first, I have used this forum many other times without actually registering to answer some questions I have had and found that the members here are very knowledgeable and helpful. Thank you, thank you, thank you.
Now moving on, I currently have a 1973 MF 135 with the Perkins 3 cyl. diesel. It appears the pto clutch disc has come apart as there are several pieces in the clutch assembly when viewing the from the bottom access hole. I do not believe that adjustment will help in this situation. The main drive still appears to be working fine. I have been looking online trying to find the clutch kit or disc to replace, however the only kits that I can find are saying 11" main drive and 9" pto, however the service manual I found is saying that the clutch is a 12" main drive and 10" pto. Has anyone replaced this clutch and know what size it actually is or where I can buy the disc or the whole kit???
I was thinking that I would replace both discs or the whole kit since I will have the tractor split anyways. Thanks in advance for your help.
