Clutch replacement
mf175s
Any idea what a shop might charge to replace pto
clutch and drive clutches on MF 175 multi power??
two stage clutch that is. Mine is going to need it
done soon. Thanks!
Thanks PTFarmer. Called a dealer, sounds like
$1,500 +- in the midwest for drive and pto clutch
replacement, new throwout and i think a carrier
bearing.
(quoted from post at 08:33:01 06/17/16) Thanks PTFarmer. Called a dealer, sounds like
bearing.
If they are any good they would also change out the input shaft seals, gasket, and the rear main seal while its apart. Makes no sense to have old seals, and gaskets inside the bell housing with a new clutch.
