I inherited my grandfathers 1976 mf 230 and a small
farm last year. I am a newby to working on tractors. I
had a lot of problems last year with it quitting. Found
out it was rust in the tank clogging up the fuelline . I
had the tank professaly redone. I replaced the fuel
line, fuel valve and added an additional clear fuel
filter. I also changed plugs, wires, oil, oil filter and
greased it up.
My first drive to bush hog and it quit. After changing
ignition coil. I found out it was the points spring had
broken. So I changed it and the condenser and it
fired right up.
When I was continuing to mow my first path the
rpm's was dropping from 2000 to 700 or less and
acting like it was going to quit. More or less I had no
power when the motor had a load on it.
Someone told me it was probably the carburetor
needed cleaned. So I removed it, to my surprise it
really didn't look at bad inside. I cleaned it with a
can of carb cleaner and sprayed out the jets. I used
new gaskets put it back together and back on the
tractor.
Now the tractor will not start. It even back fired like
shotgun. It scared my almost to death. I double
checked and the ignition coil and their was good
solid blue spark. I feel like it is the carburetor.
Any ideas? I really need to get this going. I have
worked on it since February and I am frustrated. It
was starting up and idling so good till I removed the
carburetor. I really need some help. Please and
thanks in advance.
greased it up.
fired right up.
tractor.
thanks in advance.
