steven in Tn
got a 275 that has weak hydraulics. it has a loader on it and will raise somewhat of a load of gravel but is slow,and the tilt cylinders wont even hold the empty bucket in hold position but im thinking that is the cylinders leaking, but the lift cylinders will hold the loader up with engine off no problem. used it to mow hay yesterday and it will fold the disc mower but its a struggle, checked the psi at the outlets and get about 400 at idle and right at 1000psi reved up to i would guess around 1500rpm since tac isnt working. specs show should be around 2300psi. any ideas where i should start to find my problem?
it has aux hydraulics and a filter near the pto lever manual says use 20 micron only and agco site only shows 10 and 25 micron.
