Hi - My MF 65 keeps jumping out of gear and the main gear lever is generally very sloppy with a weak internal spring. I have managed to
source replacement bits and are now trying to work out the easiest way to fit - Can the existing gear lever be removed and replaced without
having to split the tractor or remove the steering box? I guess there must be a clip or pin securing the assembly from beneath?? Limited
access is available through the oil filling port next to the gear lever but poking fingers and tools through there could be tricky then there
is the risk of dropping something in? Keen to avoid a major strip down if possible, any help would be much appreciated. Cheers, Mike
