Mf 175 auxillary hydraulics
There are many different types of quick connects for use with auxiliary hydraulics. Do you have all you implements with the same connectors, but the tractor has different ones, or?
Yeah, all our implements have JD tips, so just
wondering what tip type i would need for the 175 to
run one one of the implements. Sounds like
pioneer?
if you have the jd only male fittings you will need a set of adapters or change the female couplings on the tractor to the jd style, I prefer pioneer type as they are more common
It should use the Pioneer "ball type" quick connect.
