On a mf175, the stabilizer pin is broken. It is located in the bottom of the bracket that holds the fender to the axle housing. It is used to attach what I call the stabilizer/sway arm to the tractor.
I can see that the pin goes all the way thru the bracket.
Before I cut if off flush and weld a new one on, I wanted to check to see if anyone knows how to remove the original one from the bracket? Is it pressed in? Threaded? I don't see any retainer screws or other mechanisms that hold it in there.
Thanks!
Thanks!
