This message is a reply to an archived post by rkh on January 25, 2015 at 05:53:43.
The original subject was "Re: mf65 gas continental Oil Filter Adapter KIt, Spin On".
Did you ever get an answer to this or did you try this part? I'm wondering the same thing.
Here's the original post:
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=155008
I'm having trouble getting the filter can and the bolt to stop leaking. I got the can to stop, but now I leak out the bolt. I have a Cont gas engine. I have a spring inside the can and a tiny washer looking thing. I'm using a Fram C3 filter but the thing has about come apart taking it in and out trying to get the thing to stop leaking. Also, the Fram comes with black grommets to put inside to keep it from leaking. The grommet on the bottom pokes through into the filter when I slide it over the bolt. It's quite a pain. I changed the filter once before a couple of years ago and had no issues, but this time it has been quite the pain. A spin on filter would be great.
Untitled URL Link
Untitled URL Link
