Dave O'Brien
In reply to a question, The lift arms stay in position when the tractor is shut off.
The engine speed has to be increased for the lift arms to be operate. The draft and position controls do work independently of each other.
The hydraulic pump failed earlier this year, We replaced the soft goods (O-rings, seals, etc.) However, we had problems re-priming the system. We are now thinking that the pump may be weak. Thank you to those that have replied.
