Dave O'Brien
I posted on here a while back about my hydraulic pump. Got it working. Went to move some round bales. No luck. The lift operates with no load or just the spear on it pretty well. Tried lifting a 800-900 lb. bale. I can't hear or feel any bypassing or strain from the control levers. As an experiment, Dad tried it as well. Empty, the hitch cycled and held position just fine. I grabbed on to the spear (190-200lbs.) and no further lifting. Again unusual or valves dumping. I'm thinking the selector valve may be involved. Currently the system is overfilled in order to purge any air after a pump rebuild an difficulties in re-priming the system. It is probably something stupid. Thanks for any ideas in advance. I'll keep you all posted on it.
