Have a low hour (600hrs) 281XE that has hot hot hot hydraulic fluid! Sometimes the pumps just screams . It see to surge on the hydraulic
although it has great oil pressure at the scv's. Occasionall the steering will just stop working also! Very scary at times. Oil has been changed.
Oil filter changed. No contaminates in open filter. Sump screen pulled and check, all clean. Suction hose and pipe checked, all good. Breather
removed and checked, just fine! This tractor has power beyond block with joy stick. Pulled relief valve but it was clean. All out of answers! Has
anyone else seen this problem?
