I am trying to fix the non working fender lights on a Massey 150.
Since 2 lights are missing and the other 2 lights are not hooked up and the light switch is broken off can you tell me how they are suppose to work.
Are the inside lights suppose to be Low Beam, and the Outside Lights High beam, OR are all 4 lights the same strength / wattage. (35watt)
Also, does the OEM functioning light switch turn all 4 lights on at once OR does the switch turn on one set of lights
then with continued turn of the switch, it turns on the 2nd set of lights and the 1st set stays on also.???
or is that type of function from a non OEM switch.
thanks Keith
thanks Keith
