Lighting question on Massey 150
Rivr42t
New User
I am trying to fix the non working fender lights on a Massey 150.
Since 2 lights are missing and the other 2 lights are not hooked up and the light switch is broken off can you tell me how they are suppose to work.
Are the inside lights suppose to be Low Beam, and the Outside Lights High beam, OR are all 4 lights the same strength / wattage. (35watt)
Also, does the OEM functioning light switch turn all 4 lights on at once OR does the switch turn on one set of lights
then with continued turn of the switch, it turns on the 2nd set of lights and the 1st set stays on also.???
or is that type of function from a non OEM switch.
thanks Keith
The inner, and outer light have different part numbers (the outer lights should be brighter if I remember correctly). The switch should turn on the inner lights, then it should turn on all four lights. What is the serial number of the tractor as some of the part numbers are different starting at tractor serial number 9A 90509 (should you need any parts).
I removed one inner light. It has the rubber bezel surround, a 35 watt light, and the metal bowl that those two sit in. the metal bowl had the nut-bolt and curved washer that hold it to the head light housing. I have looked around
on Yesterdays tractor and Steiners and cannot find out what the metal bowl thing is called or any reference to it.
Any idea ?
