Christopher Mikesell
I am helping a friend with two MF 65 tractors. One has a bad lower end and the other needs a valve job. He has already sent the bad head off to be rebuilt when the other one began to knock badly. He would like to take the head off of the one with the bad bottom end and put it on the other to get some tilling done. One has a g176 continental engine and the other doesn't have a tag but the head appears to fit. We would like to know if the two tractors have interchangeable heads and the head bolt torque for the continental engines used in these tractors. The tractor with the bad head is SN sgm658042, and the one with the bod lower end is SN cgw 686635. The one with the bad head also appears to have high compression pistons.
