Hi all. I wonder if anyone would be able to help me with an issue I am having with my tractor which is an old Massey Ferguson 35. I today discovered that the switch wiring had actually fallen off two of the three terminals, and am trying to reconnect the switch. An issue is that the switch is so old that the codes on it don't all seem to be the same as I can find online. The switch actually has 5 separate terminals; there is IGN, BAT (both self explanatory) but there is also ACC, ST and also a centre one which I am certain is not used, and only seems to have a symbol next to it. The other problem I have is that - of the three wires that come out from the tractor to be connected to the switch, on of them has two wires connected into the one connector, and I cannot find anything online with a similar dual wire going into one connector. Would anyone be familiar with this type, and which wires go into what? I can double check the wire colours, and am sure that the terminals BAT and IGN would need to be used, but I would like to be more certain before I try again.
Many thanks.
Many thanks.
