Spool valve question
FlatLand9n
New User
I use the valve to supply fluid to my loader. Had to get some leaky hoses fixed but failed to pay attention to their orientation as I removed them. Basically need to know which is the supply side. Front or rear? If all else fails, I could probably just set the valve to aux and see which hose shoots fluid but I'm hoping to avoid that mess. :)
Can't seem to get a photo uploaded but basically I have a line attached to a port directly behind the lever and another line on a port behind the first one. Behind the rear port appears to be a valve. I've not messed with it much other than cleaning it up. It leaks fluid from a couple areas. Are these serviceable?
