I have a 2001 MF 231S with a Bush Hog Front End Loader. Current set up is a three way selector valve like this one to
switch to front or rear hydraulics.
http://www.ebay.com/itm/NEW-MF-Massey-Ferguson-Hydraulic-3-Way-Selector-Valve-/220828611505?
hash=item336a6933b1:g:gsEAAMXQlgtS-Rtl
The problem is I have to switch it over and put the three point in the full lifted position to work the front
hydraulics. For one, it doesn't switch well and has to be messed with to get the hydraulics working, and the other is
a pain for wanting to operated the three point with the mower on it. While I set the mower in position, move the
selector over and then use the front, the problem is when I want to move the mower up or down, you have to got thru
alot.
I am thinking about going over the one below. It says you no longer have to changed the 3 point lift to operate the
front, just change the selector.
Anyone used these? Any good?
http://www.ebay.com/itm/VFD1104-Massey-Ferguson-Three-Way-Diverter-Selector-Valve-TO35-1080-130-150-40-/230801716171?
hash=item35bcdab3cb:m:mkkhATh_LcyY5RTiFTkbClQ
Any other suggestions on what I could do?
Thanks
alot.
Thanks
