tracto-man
The diesel '64 MF 65's loader only works right after start up now. It will work until I switch the valve to use 3 point, and then after that, even if I switch the valve
back to loader, I have to turn it off, and then while it's off, move the valve back to the loader position, wiggle all the hose connections, turn it on, and it will work
again. Not sure if wiggling the hoses makes a difference or not, I just do it every time. The valve goes one way for 3 point to work and the other way for loader to
work. I am planning to change the hydroulic fluid here shortly, just haven't as it's not been used for almost a month. Could this just be old hydro fluid plugging up
line? Or should I be looking for a bigger problem when I drain out the old stuff? Sorry Brendon Warren, still not a fan. I think I have a lemon. Thanks in advance.
