The valve on the steering column is leaking from the top.
I believe there were two valves fitted on the 240; I think mine is the earlier type for which there is a seal kit available: $15
There is also a complete valve for around $200 but I think this may be the later one...not sure if they are interchangeable.
Does anyone know if replacing the 9 seals on one of these is a diy job or will I end up with a bench covered in parts ending up not sure where anything goes back. I did rebuild the steering pump and the cylinders but the valve looks quite a bit more complicated, on the parts diagram.
Thanks
Thanks
