dacaseguy
I looked on Agro parts online. I see the front bushing like you said. I did see it was worn bad. I assumed there was other bushings but worn so bad that I could not see them. Can I get that bushing from Massey? Dick
The front cover bushing is # 1753 832M1. MF 65 G176 block shows the front cam bearing # 1753 790M1. The MF 165 G176 block shows front cam bearing # is 1037 748M1. Not sure about the front cam bearing which one to get, one may supercede the other. The front nose bearing is the same on both tractors. Know cam bearings were never used on second and third journals as they ran in the block un-bushed. I don't ever remember seeing the front one but could be some did have it.
The front cam bearing should come with the rebuild kit. If all 3 cam journals are the same outside diameter a machine shop could get two more front cam bearings, and line bore the block to accept the bearings for the middle, and rear cam journals.
