Hello folks. I'm new here. I need to replace the right side 3pth pivot pin on a MF50. Haven't taken the wheels off yet but I read on this site that I have to remove the left hand axle first, support some gearing inside and then remove the right hand axle. Do I need another person to support the gears? Is it possible to just slide the right side trumpet (housing) off the axle far enough to get access to that pivot bolt leaving the axle in place or am I asking for trouble trying that? Don't know if the housing hole is damaged. A friend of mine was using the 3pth to yank out some pretty heavy logs out of the bush for firewood.
