Dave O'Brien
We have a 184-4 (Landini built) and the 3-pt. and remotes are no longer working. The oil has been changed, a new filter installed and the pump has had new seals and o-rings installed all to no avail. We've attempted re-priming the pump. Also applied air pressure into the transmission to force oil to the pump.
The draft and position levers are free and playing with different combinations hasn't helped. We haven't yet pulled the drop rate control valve or opened up the rear housing. I'm open to helpful suggestions. Thanks in advance.
