Wayne Saak
My 165 won't start after setting over Winter. The injector pump was rebuilt last Fall and the tractor was used several times after the pump was replaced. I changed fuel filters and cleaned the sediment bulb at that time. I have reprimed the system and have fuel at both bleeder screws on the pump but no fuel coming out to the injector lines. I suspicion the metering valve is stuck. Is there any way to get the valve unstuck without taking the pump back off?
Thanks for any suggestions that anyone may have.
Wayne
Wayne
