MikeBarcia
Just picked up a 135 w/ Perkins gas. Gonna run a bush hog with it but have a question first. I know to use the position control you need to have the draft control all the way back (up?) the position control does work like this, but it does not lower all the way down as it does with the draft control. I have not hooked up the mower yet so I don't know if it is an issue yet, but I was wondering if this is normal. It seems that with the draft control down the arms will come within 3" of the ground, but with the draft control back, the position control will only lower the arms to about 10-12" off the ground. Please let me know if this is normal, or is something out of whack? Thanks!
