massey ferguson loader valve help.
stiz
New User
I have a Massey Ferguson MF200 Frt end loader with a cracked control valve. I cannot locate a replacement from the dealers because it is obsolete. The part no on the valve is 707170m92. It mounts directly to the frame/tank assy of the loader. There are 2 return ports incorporated in the mounting flange. Can I get some help in determining where I might find a replacement valve or a one that can be used in place of the original ? It will need a beyond port for the backhoe feed as well as a mainline pressure regulator. And info would be appreciated>
[/img]
