Gentlemen,
I just replaced the oil pump in my 44K tractor a couple days ago, due to a broken key on the shaft that drives the internal gear(s). When I began removal of the pump I noticed that the attaching bolts were somewhat loose. I also noticed that each bolt had a hole drilled completely through the head. I suspect that these need to be safety wired after they are torqued. I have a condensed shop manual that doesn't say anything about the torque spec for these two bolts. Anyone have the specs? I know now I need a full shop/service manual which I am in the process of ordering. I would appreciate the assistance.
Respectfully, Sapper
