Danny Prosser
Thanks for all of the help you guys gave me with adjusting my 2 stage clutch. This weekend I adjusted it to .057 and now I can work the pto without shutting the tractor down. I still have to idle it down and it wants to grind just a little so I'm thinking it needs a little more adjusting when I get a minute. I checked everything out real good as I like to do before every season's first use and found a piece of metal in between the crank pulley and front end. It looks kind of like a rod bearing that is worn bad. It must be the pivot bushing so that's next. My wife is always saying every time you use of your tractors it needs something. I just say well give me about $30,000.00 and I'll buy a new one. I know they break to but that usually shuts her up!
