Curt Cooke
I think my 230 suffers vapor lock. I have all kinds of flow. When it gagged the other day, I checked all the flows and they are fine. Tractor was hot and when I disconnected the fuel line ahead of the carburetor, I noticed the fuel in the line was bubbling/foaming. The fuel line runs under the oil filter and back up to the carburetor, makes like a P trap. In the field, when it starts to gag a pull on the choke for about the count of 4 gets it back up to speed, push the choke back in and you're good to go for another little while. It's as if the fuel is boiling in the line causing a problem. Thoughts?
