MF50 Starter and Multipower Questions
Bill VA
Doing a little TLC to my trusty MF50 diesel and have a few questions - hopefully someone can help.
Was at a tractor repair place discussing some options for my tractor - a split to fix a leaky tranny seal and the question came up, multipower or
standard 6 speed. They had a 165 in the shop, which had the multipower tranny via welding two gears (don't know how this is fully done - but
clearly remember Big Dean talking about it). He showed me where the multipower dash lever was and a hole in the top of the tranny where the
linkage went vertically down into it. He also mentioned oil lines to the tranny? I told him on my MF50 - going from memory, aside from the slot
in the dash for the multipower tranny linkage and the model number tag indicating it was a multipower tractor, I didn't recall any visual evidence
the tranny had any left over linkages sticking out of the tranny, oil lines anywhere or holes on top of the tranny. He said it is possible the tranny
was swapped out to a standard 6 speed.
Going out to look again later today - question is, on a MF50, what are the tale tale signs I should see if it was multipower? Anyone have a pic
or two they could share?
Starter....
Need to replace the starter and am going to order one from this YT site. My starter is Delco Remy and has stamped on it - as best I can read:
110751 2 B 87 - kind of spaced like I show it.
When I do a part number search on the starters for MF and this starter, I find a starter, but it doesn't show it's listed for an MF50.
Is it possible the engine on my tractor came from another MF? Without a doubt, it is a 3 cylinder Perkins diesel and is indirect injection (straight
injectors).
Given the tranny, if it has been swapped the starter mystery - wondering if my tractor is a hodgepodge of other tractor parts to make a running
MF50.
Visually, nothing out of place - has been a GREAT tractor, just curious.
Any clarity provided is much appreciated.
Bill
Sounds like your transmission was swapped out. The starter for your tractor fits several other models like the 135 with AD3.152 Perkins, the current AGCO part number for the starter (MF50, MF35, MF135, MF150, etc) is 191081M93 (Delco Remy number 1107-853)
Just took a few pics of the transmission and starter and ID plate. Don't know if the number on the tranny housing will come through or if it matters, multipower vs 6 speed.
Note where my finger is pointing, there is a slotted pan head screw there. Don't know if that's factory or covering an possible access hole for the multipower or something else.
I'm asking about the multipower - just out of curiosity. Interested in the history of this tractor.
Thanks!
Bill
The "W" in the prefix of the serial number indicates it should have multi-power. a lot of people do away with the multi-power because they can be very expensive to fix. I like the multi-power, I have a 135, and 2135 industrial with 6 speeds (that I wish had multi-power), and when shredding 2L is too slow, and 3L is too fast. When I used my brothers 150 with multi-power to shred running in 2L, and High range on the multi-power the speed is perfect.
