MF 259 field cultivator
Have this MF 259. 30 foot. 3 lift cylinders, phased. Left cyl extends full, center cyl about 2/3, right cyl about 1/2. Have tried phasing procedure several times to no avail. return oil from right cyl to tractor is working. any ideas, Thanks, Swede
Thanks for your reply. After much head scratching I took the right hand cyl loose from the machine on the top pin fully extended the cyl manually, filled it with oil, reinstalled and it worked as it should. Don't know yet how it lost oil, no sign of leakage. Thanks, Swede
