Sorry, been having problems replying to the thread below about the master control spring, so here goes, but with a new topic to kick it off - moderators if you can move this to where it needs to be that would be great - thanks
Is the 1/8" of slack in the yoke or in the spring? When you reassembled the new spring etc., you should do up the adjustment on the threaded bar that runs through the spring until you can only just turn the spring by hand, then lock everything off, and put everything back together.
Draft control is [i:69c0990bf8]very[/i:69c0990bf8] sensitive - there is a tale over here that an old boy used to bet someone he could lift a three furrow plough with one finger - having got a load of bets in, he would then walk to the back of his (running) tractor, and gently lift with one finger on the rearmost plough share - and the plough would lift.
A mate of mine over here has uploaded something similar to YouTube click here https://www.youtube.com/watch?v=uvtFPwNPgAE
To answer your question though, if the top link is 'pushed' against the tractor, linkage internally will operate the lift on the three point, and if the top link is 'pulled' the internal linkage will lower the three point to maintain a constant draft on the plough (for example).
The advantage is that if your subsoil implement hits an obstruction, like a stump or rock, then the plough is lifted and safety for the driver is returned - this was why the Ferguson system was a revolution in farming.
Before this, dragged implements were responsible for killing a number of people every year when stumps/rocks/whatever were struck by the plough, and the tractor overturned backwards, squashing the driver.
