Knivens894
New User
I have a 1962 MF 65 with direct injection Perkins A4D-203 diesel engine which was just completely overhauled. I set the timing gears at TDC, with No. 1 rockers in neutral and No. 4 going down. The manual says I should have a "C" in the injector timing window but that is not possible to obtain. I checked the spill of the No 1 injector at 20 BTDC and it appears to be correct. Is the manual wrong or does anyone know of a reason why it would be different?
The injector pump has a master spline and cannot be changed. The injector drive dowel will only connect in this one position. The gears are factory marked and installed with all marks correctly meshed. The mounting studs for the injector pump only allows minor adjustments.
