Crazy Horse
Just finishing up a Massey Harris 20 and I realized that once all the tin is bolted on, changing the light fuse (which is located on the 3-position charge/light switch on the dash) is pretty much inaccessible. Looks like a guy would have to remove all the bolts that hold the dash into place but even then, getting that dash loose and shuffled up the steering column for rear access makes me wonder how easy that is going to be. I should have just hotwired that fuse holder in the switch and then put an in-line fuse holder in an area more accessible but it's too late for that now. It's been ten years since I tore the tractor all apart so I don't remember how easy it was to take everything apart.
