Cannot put TO30 into any gear but PTO still engages
panacasummit
New User
I was pulling a box blade and got stuck and rear wheel started hopping and spinning. Engaged clutch, lifted blade, backed up, went back to neutral to go forward again and cannot get into any gear. PTO still engages and works properly but machine will not move anywhere. Transmissions and clutches are two things I know nothing about. Point me in the direction to learn here.
your gear shifter cam out of the rails in the trans. remove cover line things up and it should be fine . when you shifted you lifted up on the gear shifter and it came out not a big deal
Oh I would be shocked and grateful if it was something that simple. My life never goes that easy. :D I shall give it a try as soon as I get a day off again.
(quoted from post at 20:49:28 04/06/16) your gear shifter cam out of the rails in the trans. remove cover line things up and it should be fine . when you shifted you lifted up on the gear shifter and it came out not a big deal
Yes it was that simple. Thank you very much. Didn't even have to take the cover off. Just lifted up the lever playing with it on the way by to my truck to head to work and it popped back in place. Thanks again
