Georgia088
Mf industrial 30 keeps getting either air or trash in fuel. Sometimes it will run hours with no problems. sometimes it will run 5-10 minutes. and then its like the tractor runs out of fuel. I have to bleed the lines at the filters and then the injectors and it will fire back up. and run for a while until it happens again.
I have put new rubber hoses on from the tank to the fuel pump with clamps. It is a new "diesel" electric fuel pump and new filters. I just rebuilt engine on it.
Is there an easy way to determine where the air/trash is coming from?
Now when I bleed the fuel filters, there is very foamy and bubbly fuel coming out. and it seems to not get any better no matter how long you let the fuel pump out of bleeder valve.
Thanks!
Thanks!
