I just got done replacing the bushings in the frame, tie rods and drag link. The steering arm was wore, so we welded it up and machined it back down to size. Everything is tight. I also rebuilt the steering cylinder.
Now it almost seems worse on the road than it did with all the loose parts. It takes a lot of movement of the wheel to get the steering cylinder to engage. If I try to tighten that up by tightening the set screw I loose power steering. Its hard to imagine that its suppose to be that way. Looking for some more places to look for problems. Thanks
