135 3 point wull not work
dmbinva
I posted this in the wrong forum to start
It has remotes and they work. The 3 point will not come up . when I put it in constant pumping the engine does not die down. I remove the side cover and the arm that moves the roller is working as it should. Is there something that would shut off the 3 point when the remotes are working? Help please
Boss
Hello, do you have remotes operated by an auxillary pump or are they supplied from the valve assembly on the front of the hydraulic cover? If the latter make sure that you have 'INTERNAL' selected to operate the 3-point linkage. You will need to select 'EXTERNAL' to use any remote assembly with pipes originating from the hydraulic cover valve irrespective of what type it is.
With 'EXTERNAL' selected I'm guessing that you have control levers mounted on the cover valve. In this way oil is being pumped up through the valve and returned to the transmission.
Let us know what you find.
DavidP, South Wales
On my 135, the 3 point position control operates with one of the remote levers. To get the draft control to work, I have to pull the same remote lever to the raise position detent. the draft control then operates the 3 point arms. when the arms get to the top of their travel. the remote lever pops back into the center position. Is that normal operation or am i missing something?
So you have the valve that is shown in the bottom of this picture. Having used both I prefer the diverter valve (shown at top of picture) with the remotes mounted elsewhere.
I do have the hydraulic operator manual for the 130 - 180 Massey Ferguson tractors. I have the manual in a Adobe PDF file. The pictures are not very good, but if you want the manual send me an email to: [email protected] and put "hydraulic operator manual" for the subject, and I'll send you the hydraulic operator manual file.
I have the valve on the lift civer like a ford , I see no way to adjust it
I will try and get some pics
Thanks Boss
