Hello,
I have a situation with my '48 MH 44K oil pressure. I started it last Saturday to back out of my barn and it started to knock a bit. I noticed that it had zero pressure, so I shut it off to look for oil leaks and level of oil on the pan. So far so good. I started it again with the same result and I shut it down. It has new oil and filter and rebuilt filter canister and hoses. It had been registering 10 to 15 psi when running and showed no signs of failure. It has the Massey Harris 4 cylinder engine. I am in the process of removing the oil pan to examine the pump. I have a condensed shop manual (IT) that shows basically what the pump consists of along with an assembly manual that I copied (page-by-page) from the Massey-Ferguson website. I need to know if anyone sells a rebuild kit for this model of engine, and if it is a straight forward bit of work to remove and rebuild the oil pump. Sorry for the detail. I appreciate any assistance given me concerning this matter.
Thank you all,
Sapper
Thank you all,
Sapper
