Help with carb numbers
lurp66
New User
I have a MF 150 with Z-145 continental engine. I need to rebuild the carb, but after removing & cleaning it with gas & carb cleaner, I'm not able to find a carb number or tag. There is several numbers stamped on the carb body, but none match the various numbers for the carb kits listed. It's a Marvel Schebner carb. The mounting studs are 2 3/8 inches center to center. Is there any way to determine which carb it might be? Any help would be great.
(quoted from post at 13:50:03 03/26/16) About the only useful part in the kits is the gasket which can be cut using the old one for a pattern
GCO online parts shows it to be TSX 882. However they show 2 differant #'s : 194065M91 1 (C) Carbureter Assembly (Marvel Schebler TSX,882, #8-4718X)
194065M92 2 Carbureter Assembly (Marvel Schebler TSX882, #8-4718) you should check them out on the AGCO web site before ordering. Book 651200, 150 Tractor and look for carburetor (continental gas).pg's 58 & 60.
Marvel Schebler TSX 882, #8-4718X used prior to tractor serial number 642001840.
Marvel Schebler TSX 882, #8-4718 used from tractor serial number starting at 642001840 and up.
ptfarmer
Poster did not give serial # of his tractor, so that is why I replied as I did, besides I was trying to teach him how to fish. :wink: :wink:
Lets see if he asks the next obvious ??
