Mf 135 neutral safety switch
petehall
Im having to rewire mf135 due to all wiring shorted out
Im putting on 1 wire GM alt and delete voltage regulator
QUESTION
From where to where so the neutral safety switch works?
Thanks for any help
Pete
You run the wire from the starter switch to the neutral safety switch (nss), then a wire from there to the start terminal on the starter solenoid. The nss do go bad, they will usually result in no cranking.
ptfarmer
I just tried it and works good
I was hung in my head that it was like the old Fords and made a ground to complete circuit
Thanks for the help
pete
