Power steering
Need a PS hose for my '64 MF 65. The hose on it is part medal part rubber, and the rubber part is burst. Bringing the dang thing all over town and the hydrolic "pros" keep sending me to the next place. One company says they can make it but only all rubber with the fittings on each end. So would all rubber work? I believe I could buy the hose new at one place but it'd cost around $280 which I really don't want to spend as it needs a new radiator as well. Or do I need to keep chasing all over the place trying to find a place that can make it with the metal?
In your case the all hose will work, if you get something that needs the pipe there is a compression fitting that can be made on a new hose end, if the people you have doing the hose work know anything about them.
