Hey all, the governor recently went up in my Massey. I went to replace it along with both timing gears. Got it all back together, timed and torqued the governor. When I ran it there was a vibration in the front end. Pulled the timing cover off and found the new crank gear is loose on the crankshaft and had slide forward a quarter inch past the cam gear. I can wiggle it a little with my hand while it is on the shaft. Is it normal or okay for the gear to be this loose? The old one was on there good and tight. I will get a tool to measure the shaft diameter but am not sure what it should be. Thanks in advance.
