No clutch on MF 30
please help, driving tractor down slight hill today and when near bottom I pushed the clutch in to just coast for a bit then before letting clutch out again I shifted from 1st to 2nd, when I let the clutch out nothing happened it is like it is staying in neutral all the time.
I do feel resistance in the clutch pedal although not as much as before, I am going to adjust the free pedal as it is now about 1/2 inch where the manual says it should be 1/8 inch hoping the further range of motion may free up the stuck open clutch plate ?
There is a plate on the bottom of the bell housing that is held on with four bolts. That hole is used to adjust the clutch, but it sounds like something broke, or came apart. You may have some clutch parts fall out when you pull the cover, you can also look in there, you might see something broken.
