MH 44 engine
I will start the postings, do not know, but hopefully someone will.
Sometimes you have to prime the pump.
Should, if the tub is the same; the 44 engine uses the bolt hole behind the dowel pin to locate, whereas the shorter 33 engine uses the bolt hole in front of the dowel. There is also two sets of holes for the front engine bolt mounts. You will need to use the 44 hood, and IIRC, move the rad ahead a bit as well. Clutch shaft may have to be changes as well.
Ben
You need the clutch and bell-housing from the 44 (the 33 had a smaller clutch). The 44 radiator is bigger, so it would be better to use a 44 rad. You should be able to use the 33 hood ( double check the measurements of the two ). If you are using the 33 air cleaner, you do not need to use the spacers when bolting it onto the 260 ( that way it lines up with the hole in the hood ).
