Its back on all four
Brendon Warren
It took some doing but we wet at her with shovels and high lift jacks and some brute ignorance but its together. I decided to fix her right there. I still need to replace an inner tie rod and tube but at least its out of the slop. The front pivot casting broke. It appears to have been welded before.
I would have sure hated to do it setting there. Did you have any trouble getting bolts loose? Wandering also how far from house or shop, guessing you made several trips. Good job!!
Yes four trips. I've got an 18v impact. Lifesaver, 1/4 mile from home. It turned out more worry than work. I was knee deep in slop the first time I've busted out the coveralls this year.
