5455 wet clutch?
I'm going to look at a 5455. Owner thinks it's tier 2, ser. M290040. He says it's 8 x 8 with electric/hyd rabbit/turtle. It has a clutch issue. He claims it's a wet clutch with mechanical(not power) shuttle. I can't find anything in parts diagrams for early or late series tractors that matches his description. All the wet clutches I see are power shuttle or dyna 4. Does anyone know if this combination exists or not?
Hi Harry,
There are two types of 'Wet Clutch with Mechanical Reversing Gear' listed. One is up to SN P186029 and the other from P186030.
DavidP, South Wales
serial Number M290040
Parts Book
MASSEY FERGUSON 5455 TRACTOR
Model Year: 2003
Warrany Warranty Information
TWO YEARS / 2000 HOURS
Start Date: 03/25/2005
End Date: 03/25/2007
Component Serial Numbers
CAB NUMBER N06337
ENGINE NUMBER RG37826U098712K
GEAR BOX NUMBER BM287335
REAR AXLE NUMBER PM287561
Bill of Materials
AD002 ADJUSTABLE STEERING COLUMN
AE019 MECHANICAL SWIVELLING SEAT WITH ARMRESTS
AF001 AERIAL AND SPEAKERS
AI019 STANDARD
AJ001 SEAT BELT
AL001 EXTERNAL MIRRORS
AM015 STANDARD CAB
AQ001 AIR CONDITIONING
AU003 STANDARD SHEETMETAL
BA005 ANALOGUE & DIGITAL INSTRUMENT PANEL
CE014 THERMOSTART STARTING AID - 80 AMPS ALTERNATOR
EA602 16/16 SPEEDSHIFT - 40KPH
EC001 MECHANICAL SHUTTLE (DRY CLUTCH)
ED001 STAGE 2 ENGINE
EG001 OIL COOLED DISC BRAKES
GC027 CAT 2 TELESCOPIC BALL END LINKS
GO001 STANDARD ENGINE RATINGS
GP013 2 OC SPOOLS : SA/DA FD KO + DA KO FLOAT - 57 L/MN
GT054 ELC WITH NORMAL LIFT CAPACITY
LA006 EXCHANGEABLE SHAFT PTO - 540 RPM 6SPL + 1000RPM 21SPL
LB001 PTO LOCK OUT
LC001 STANDARD PTO DRIVE - 2000 ENGINE RPM
NA004 2WD - HEAVY DUTY FRONT AXLE
TC001 ENGLISH LITERATURE
TD001 ENGLISH DECALS AND PLATES
TG002 SPEEDCHART IN MPH
VC008 WET CHARGED BATTERIES WITH JUMP START POINT
VF003 SMV TRIANGLE
VG019 2 FRONT AND 2 REAR DOUBLE BULB WORKLIGHTS
WD012 2.00M WIDE REAR FENDERS
WG006 WITH TOOLBOX
YA002 FRONT WEIGHT FRAME AND TOW PIN
YG001 HEAVY DUTY VARIABLE FLOAT TELESCOPIC STABILISERS
YM027 STANDARD SWINGING DRAWBAR - SAE
ZAUS9 NORTH AMERICA
ZB004 ERECTED TRACTOR WITH 50% ANTIFREEZE
ZC001 FULL SET OF QUALITY TESTS AND OIL LEAK SEARCH
ZZ738 MF 5455 - 100 HP (ISO) 4 CYL
here is the build sheet for that tractor says its a dry clutch
Interesting, to say the least. Do you mind sharing your source for this information? I can't help but think this would be of great help again in the future. It was my suspicion that this might actually be a dry clutch tractor by what I see in parts diagrams, but at this point until I see it first hand, his description/info is all I have to go on.
Thanks all.
I work for a MF dealer and I can run serial numbers and it will give me the build sheets I can only go back maybe 10 years...I come on the forum from time to time I don't help much mainly because David P beats me to it that guy is spot on
Actually, I was fooling around last night and discovered the same list on the AGCO online parts catalog. I have noticed the box labeled search by serial number but had never tried it. I selected Massey Ferguson, typed the number in the box and there it was.
