OK, i have searched the forums for a while longer with no success. Had the tractor all apart. Back together now. The IPTO starts slow, no pressure on a gauge at the Ipto test port on the side. Not sure about the multipower but fluid moves on through the front main bearing it looks like on the low side and blows through the small holes on the clutch in the transmission on the high side. The IPTO clutch looks the same. I have it narrowed down to one of five things. If you call that narrow.
1. AUX Dual pump has one bad side. The aux hydralics on the back work.
2. The valve in the bellhousing.
3. The relief valve on the pump.
4. The IPTO clutch not holding pressure.
5. The multi clutch not holding pressure.
4 and 5 look to be the same so now what?? Thanks for the replies and insight.
