tysmobiletractor
I have a MF 65 I am working on.
The 3pt arms were stuck in the up position. And would not go down.
I pulled the cover off and the screen was off the pump and debris from the screen was floating in the oil. So I have pulled the cover off - removed and replaced the complete pump with a new pump - cleaned a bunch of crud from inside before the new pump was put in. Cleaned the filter for the multipower which was not working either.
So now it has new pump - clean new oil - clean filter for multipower - also new 3pt cylinder which was scored that I replaced along with new piston and new rings.
All back together still same....3pt is up and will not lower.
It looks like the lever to move the 3pt up and down is not pushing the lever on the pump.
If I push the pump lever with a bar manually from reaching through the cover the pump moans and seems to push out the pressure relief valve.
Let me know any suggestions.
Thanks so much..
Thanks so much..
