steering gasket
willowbk
Hey guys, wondering if anybody has a line on steering housing gaskets for f40/mf50.
Part number is 1751732m1. It is the gasket behind cover below steering wheel.
Tractorhouse shows some available but company never updated stock inventory.
I have used gasket sealer before but would like to use original if still out there.
Thanks.
If its the one that has adjustment screw in cover I never was able to find one. I just clean it and use silicone or good gasket sealer. 3M red sealer.
I'm working on an f40 single wheel, my parts book calls for the 175173m2 for single/twin/utility and hi-arch.
I did find same part number on a few mf50 models. Seems like it had various applications.
Hopefully we can find some.
No, it was a high crop wide front I'm converting to single wheel.
I found the single wheel front end in Pennsylvania.
I will let you know if I find some gaskets.
Do you know a supplier that has serial # tags. The single wheel will need a TGM on tag. I need one also. I've seen a single wheel tractor with the T tag near Vienna Ohio but don't know if it was original or he stamped it.
