Massey super 90 oil leak
Anola
My super 90 after 20 minutes running pours out of the clucht housing. This tractor has multy power I know the tractor will have to be split what should be looking for. Thanks for any info.
Hello
You have a hydraulic hose that has a wear mark on it. The multipower shifter that goes down into the housing on the right top side will rub on one of the hoses, every time you shift the MP.
This is my best guess, have fixed a couple of these already, and have one more to do right now. You will have to split the tractor and remove the Multipower clutch pack...be careful that you don't drop the clutch pack on the splines, when removing (And installing)...you will damage the aluminum housing.
all this for a 2 foot hose.
Wayne
Depending on how big the hole in the hose is...it will take a bit of time to fill the cavity in the clutch housing, where the weep hole is. This may NOT be your problem either. In my experience it is just most likely.
How much oil actually leaks out when it starts to leak? does it just drip, or is it a steady stream?
Wayne
